We have got the below query.
We have installed the Demo Version of AX 2012 R3 CU8 on Azure using LCS. We can find the module called “Data Import Export Framework”.
I have a scenario to import Customer & Customer Address using DMF where the source file will be a .csv / .text file.
I was going through the documentation on msdn, I just want to ask, is there any installation required for DMF on the Demo Version of AX 2012 R3 CU8 on Azure to import customer / customer Addresses using DMF.
If yes, would appreciate your help on how to install the tools if at all required since it is installed over Azure OR the pre-installed module “Data Import / Export Framework” is the one that we need to use for importing & Exporting data from AX.
Would appreciate for your quick response.
Muneeb
