Hello,
When I create SalesOrder then select number sequence group in Setup Tab & posting the PackingSlip.
when posting the packingSlip that time numberseq is insert into the CustPackingSlipJour table i.e packingslipId. but How it is Possible?
because I customize the WMSPickingRegistration Form. means i have added the number sequence group field in this form.
Now i want to insert the number sequence related that group in to WMSOrderTrans Table.
How it is Possible?
Please help me.
I think you are taking about the OrderId in WMSOrderTrans…
Do you want to change the OrderId according to the number seuquence selected. Is this your question…
yes, i can change OrderId format. But I want Two Number series for Domestic and Export invoices.
I think you are able to differentiate the sales orders by domestic and export…
The orderId will be first created in wmsOrder not in wmsOrderTrans…
so you need to insert a number in the OrderId field of wmsOrder table…based on the type of invoice selected for that salesOrder…
for that
You add one more number sequence…(hope u know creating a number seq)- (refer WMSParameters Table → numRefWMSOrderId)
Then try to override the class → wmsCreateOrder → updateCreateWMSOrder method…
