A report that gives list of all modified objects? please give the solution for above query, which function can i use for this? |
There is no standard function for this…
You need to take Object table as dataitem and set filter on Modified field as Yes…
And that only works if the Modified field has not been changed manually.
The best is to use a tool like Mergetool - here you can get a report of not only which objects has been changed, but also which changes are done. But I suggest that you don’t go there now. Not before you’re more familiar with NAV in general! Mergetool is not for beginners.
