I want to create a form with grid control in it. and I need one field in that, which shows row number. like
Sr. No. ID Name
1 DAT-0001 ABC
2 DAT-0002 XYZ
3 DAT-0003 PQR
So, My question is How can I create this “Sr. No.” Field in Grid of Form ???
I there any property for doing that or need to do any Code for it.
Sumit
Hi Sumit,
Create one new number sequence on that form using below link then the number will be allocated in the Sr.No filed automatically when you press Ctrl+N.
Try this link:http://axaptacorner.blogspot.in/2012/09/generate-number-sequence_8531.htm
Hi Sumit,
Hi Pandu,
Is there any other way to do that… like in SSRS report we use RowNumber(Nothing);
Hi Sumit,
You can set the counterField property of form datasource to the field which you want to increase.This will do magic.
Thanks & Regards,
Britto John Baskar.A
Hi Britto,
Thank you… It is really working for me…Great…
regards,
Sumit
Hi Britto,
I have tired using CouterField in the Form Datasource for a field which is real (EDT as LineNum at table level and it is the index for the table). But, I am getting Values like
1.00000
-1.00000
-2.00000
-3.00000
and so on for the new records.
Can anyone please tell where I am going wrong.
Thanks in advance.
