Create a form in AX 2009
Hello Friends,
I want to create a new form in ax 2009.
1st column of form suppose Type (enum field- value A & B) when we can click on new button then select the A the 2nd column automatically select the new number sequence (e.g 0001_A) and when we select B then Number sequence is (0001_B)
e.g Type Number
A 0001_A
A 0002_A
B 0001_B
A 0003_A
B 0002_B
Please help me
Hi Darshana
As for you requirement only two column in grid,
First Column your Enum field(like a lookup),
you are writing X++ Code for Number Sequence in the Modified method
also do it basic procedure for number sequence
So Whenever user modified first column, Second Column should be Value of Number sequence.
Hopefully it will help u.
Thanks & Regards
Syed Abuthahir
