I have requirement in the form …
when we click “Ctrl+N” for new record in the form i want to display automatically get Serial Number in the Grid…
(Ex:first record -1,secondrecord-2…etc)
in Form Design
please Help Me…
in Form Design
please Help Me…
you need to set number sequence for that field.
Refer http://dynamicsuser.net/forums/p/32430/170165.aspx.
Jatin Dave
Try the following procedure
numRef.dataTypeId = typeId2ExtendedTypeId(typeid(NoobEDT)); //Extended datatype related to NoobId.
numRef.referenceHelp = literalStr(“HelpText”); // Your help text to be viewed in Parameters later.
numRef.wizardContinuous = true;
numRef.wizardManual = NoYes::No;
numRef.wizardAllowChangeDown = NoYes::No;
numRef.wizardAllowChangeUp = NoYes::No;
numRef.wizardHighest = 99999999;
numRef.sortField = 1;
this.create(numRef);
2)Then go to Table node and find InventParameters, go to methods node then add a new method and write the following:
server static NumberSequenceReference numRefNoobId()
return NumberSeqReference::findReference(typeId2ExtendedTypeId(typeid(NoobEDT))); //Extended datatype
3)Then go to Inventroy managment content pane → Setup → Parameters → Number Sequences Tab
now here you will see the Extended Data type NoobEDT and an empty Sequence number code, right click the empty lookup and click Go to the main table Form.
Add a new number sequence code in the opened form and save it [for example]:
Number sequence code: NoobNumberSeq
Smallest: 1
Largest: 99999999
Next: 1
Format: Noob_########
InUse: Checked
Return to previous Form “Parameters” and choose NoobNumberSeq that we have just created it from Number sequence code lookup to NoobEDT Reference
3)Last thing to do is Go to NoobsForm → Datasources node → NoobsTable → Methods, and override method (create) and write the following:
public void create(boolean _append = false)
super(_append);
NoobsTable.NoobId = NumberSeq::newGetNum(InventParameters::numRefNoobId(),true).num(); //numRefNoobId() is a method created in step 2)
//End
Finally go to the form and create a new record and you will see your number is generated automatically and sequentially.
