Number Sequence for Report Generation.
Can you please help me in creating a Number Sequence Report wise in Ax 2012 .
What I need is each time when I click the menu item button which prints a SSRS report a new nuber sequnce should get generate for that report .
Next time when the same report if printed again should get visible with a new number sequence.
Please help if any one knows the solution ,its very urgent.
Thanks in Advance…
hi
Use This Step to Solve Your Problem
1- create new number seq in basic - > number Seq
2- Create a Class and copy This Code into In (Name is :Next_Number_sequence)
3- in classDeclaration :
public class Next_Number_sequence
str My_Serial_Number;
numberSequenceTable numberSequenceTable_new;
4- create new method and copy This code :
str Get_Next_Number_Seq(NumberSequence NumberSequence1)
select NextRec from numberSequenceTable_new where numberSequenceTable_new.NumberSequence==NumberSequence1
My_Serial_Number=numberSequenceTable_new.Format;
My_Serial_Number=strDel(My_Serial_Number,strlen(My_Serial_Number)-strlen(int2str(numberSequenceTable_new.NextRec-1)),strlen(int2str(numberSequenceTable_new.NextRec-1)));
My_Serial_Number=strins(My_Serial_Number,int2str(numberSequenceTable_new.NextRec),1000);
My_Serial_Number=strReplace(My_Serial_Number,"#",“0”);
return My_Serial_Number;
5 - call it in your form , Report and …
Next_Number_sequence=new Next_Number_sequence();
InventDim.inventSerialId=Next_Number_sequence.Get_Next_Number_Seq("name of number seq ");
