I guess you will have to install the software so that you can input “Urdu language” on that text field. The text you entered will be saved to the database in “Urdu language”, so that your report will show as it is on the SSRS. It’s not related to AX label, so don’t worry, just install the software first, and switch over to the input language and change it back to Engilsh when you want to.
