How should I import inventory with serial no.?
You need to create a dataport / xmlport which will accept the Item Journal and then via code will insert item tracking with serial no details for each line.
If it’s NAV 2016, then you just import them normally. No additional code reuired.
Thanks Saurav!
Hi Erik,
Yes I am using NAV 2016, so u mean I can using Config. package to import that?
What do you mean “import them normally”? I can’t find a table that contains Serial No’s… Where in NAV 2016 can they be imported?
