hi everyone, how to insert a picture (JPG format) into the navision 4.1? Do you hav any solution? [:D] thanks,[8D] kit
Navision cannot handle any other image format than BMP. Therefore you can load a JPG (or any other file) into a BLOB field, but this does not allow you to display it somewhere inside Navision.
Originally posted by tb@softsys.at - 2006 May 02 : 03:08:54
ok…i know already…thanks you… have a nice day…[8D][8D]
Open windows paint and save it as BMP. Import or load the image. IF you just want the user to see the image as a JPEG, if they click something, then just point to the file in a hyperlink C/side coding. Explain Item card. Added coding for the user to find file with the Item No. then .JPG extension. Ex: No.: 7000 Hyperlink and find: 7000.jpg. The system will open the file in the viewer installed on the windows computer.
thanks all of you so much… my problem solved already…[:D] close case now… have a nice day…[8D]
