Is it possible to change the font in a dialog window? One of my clients is using an add-on product for shipping that uses a dialog window to prompt the user for quantities, lot numbers, etc. I would like to make the dialog window larger so that the warehouse guys can see the prompts from a distance. Along the same lines, is it possible to change the default fonts for forms and reports within Navision without having to change this on a form by form or report by report basis? I looked in c/u 1 but didn’t see anything there. Thanks!!
Hi Mark, you can substitute fonts n Windows that will give ou the effect you want, but it means hacking each computer, and is not really what you are after. In the end on the forms, its a pretty quick task to go through and change all the fonts. You will sepnd more time trying tricks with text editores etc. than just clickng away and getting it done. For the Dialog boxes, just change these to Forms.
