Hi, could somebody help? I found that most report in Navision are OK, but fonts aren not. So I thin the easiest way is not to change fonts one by one, every record on a report. May be I export the report and just replace Helvetica with Ariel in Word. I suggest that you have better suggestions how to make this. Thanks in advance.
The easiest would be to change DeviceFontName in the report properties. This works with Navision 2.0 and on. Best regards, Erik P. Ernst, webmaster
I have tried changing the DeviceFontName-property on an existing report, and it works fine on Labels. But it has no effect on Text-boxes! I’m running the report in NF 2.5 but it was originally designed in NF 1.3. Could this be the reason??
