I want to make Report which display Status of the ITEM up to any Date…
I.e I want to select Only those entries from Item Ledger Entries table those are Filtered by Given Date and Want to Display Status of Item up to that day… i.e Inventory , Net change and Other FlowFields…
Please Help Me…
So you can use for following functions to calculate flow fields
Item.CALCFIELDS(Inventory )
and then display on report.
You have to check each flowfields CalcFormula, If it has Date Filter in it then it will work as per the dates given ex: net Change already has Date Filter in calcFormula…
Hi Mohana,
Thanks a lot… There was not date filter in FlowFieid Calculation Formulla… So I have Include it.
Thanks…
in which field you have added…
