I’ve got this code; Any ideas?? NAV doesn’t seem to copy this filter across like it does for the other fields.
Table.RESET;
Table.CALCFIELDS(FlowField);
Table.SETFILTER(FlowField,Code20Field);
Form.SETTABLEVIEW(Table);
Form.RUN;
Table.RESET;
Form.RUN;
Welcome to DUG…
this is not because of your Flow filter…why do you need Table.CALCFIELDS(FlowFilterField); for flow filter?
Read help files for CALCFIELDS…
Problem with below code
Form.RUN;
Oops - I meant a flow field
(not a flow filter field)
try
Table.RESET;
.SETRECORD(Table);
.LOOKUPMODE(TRUE);
IF .RUNMODAL = ACTION::LookupOK THEN BEGIN
?? begin what?
What do you want to do after running the form?
the above code is to run the form and select a value from new form…
