I added a flow field to a StarShip table in Navision and it works fine. The correct info is in it.
I added it to list view form of the table and it shows up fine.
When you go to filter (F7) or hit the spyglass filter and enter criteria in - it doesn’t work.
Even when I run the table outside thru Object Designer it won’t filter on this flow-field.
Am I missing something??
Thanks in advance,
Greg
