I have a report which displays the following info and works fine. (these fields are all from ItemLedgerEntry.
Pallet No, Box No, Item No, Item Desc, Item Weight.
Pallet1, Box1, Item1, Item1Desc, 20kg
Pallet1, Box2, Item1, Item1Desc, 20kg
etc.
I want to add a field that has the number of pieces in each box.
I have link the field “box no” between ItemLedgerEntry and another table “Trade Items” and I’ve added in the “Pieces” field.
And it’s worked, however… my results look like this…
Pallet No, Box No, Item No, Item Desc, Pieces, Item Weight
Pallet1, Box1, Item1, Item1Desc, 0, 20kg
Pallet1, Box2, Item1, Item1Desc, 9, 20kg
Pallet1, Box3, Item1, Item1Desc, 9, 20kg
For some reason the “Pieces” the very first record always displays 0, (if I look at the data it says “9” pieces for Box1). I can’t fathom out why it’s not populating the first record correctly, but does populate the subsequent ones correctly.
I feel I’m probably making some kind of rookie mistake here, can anyone please advise?
