When FinSQL.exe starting up on a Citrix XP Server. You can’t login to the database. If you try to select the database the client end his execution. Also when you type the database name your self and you click on the OK button, you get the same result. The client is a 3.60 version. We don’t get any error codes. The client just closed. We installed with the standard installation tool. The Fin.EXE does work in the Citrix enviroment. Can anyone give me a hint in how to solve this ?
Solved ! [:)] for anyone who’s interested. It was an MDAC problem. Citrix XP servicepack 2 was installed and it comes with MDAC version 2.70. 3.60 uses MDAC 2.60 as a standard. After installing MDAC 2.80 the problem was solved. Now the client starts and the database lookup works fine !
