Can I know how how to get the Dimension value report in Ax2012 .If i used dimension set , i can able to get only dimension report but i need dimension value reports or transaction . Where can i get all the dimension value reports in AX2012 Please solve the requirement
Can you please elaborate what exactly are you looking for in dimension value report?
Dimension set is the best option and if you create and use dimension set with combination of other ledger or dimension then you get the financial values in trial balance report.
Apart from this, if there is any other report, we can easily create it using financial statements.
Pranav…
Dear Pranav,
My scenario is
I have one dimension Branch under the branch 1) Delhi branch 2) Chennai 3)Mumbai …
I need Delhi report , Chennai report ,Mumbai report …
Hi Rupesh,
In that case you can create a dimension set for Main account and Branch.
Run the trial balance report with filters as required. The report will generate balances for a ledger dimension wise.
Pranav…
