Trial Balance with respect to Business Unit
Hi Pioneers,
I have 2 Business Units, named A & B, and I want to filter my Trial balance report in ax 2012 on the basis of Business Units. Please suggest me the approach. I have checked all these tables:
  • DimensionAttributeValueCombination table
  • DimensionFocusBalance table
  • GeneralJournalAccountEntry table
  • LedgerTrialBalanceTmp table
But in all these tables, I didnot get any field of Business Units. How can I associate that field ? Please suggest.
Click the select button aft cliking the Trail Balance report Menu item. There the Business unit field will be available.
It will be like LedgerAccount.BusinessUnit. And select the desired values.
Hope this will help you.
Madhan
Hi Madhan,
Thanks for your prompt reply. But there is no such “LedgerAccount.BusinessUnit” in the dropdown. Please help.
Please reply.
There is no such field in that table. Please reply.
When you navigate to General ledger > Common > Trial balance, there should be a dropdown at the top with the label Financial dimension set. There you should be able to choose BusinessUnit and the Trial balance page will show a breakdown by BusinessUnit.
If you have not yet setup a financial dimension set for BusinessUnit, then navigate to General ledger > Setup > Financial dimensions > Financial dimension sets and create one. When you have, then click the Rebuild balances button in the action pane so that AX will calculate the per-BusinessUnit balances for your new financial dimension set. Once you’ve done all of that, then the steps in the first paragraph should work.
Hi RiPi,
Thanks for your prompt reply, I followed your previous discussed steps but I didnot get my solution, kindly requested to look after this matter.
Thanks in advance
Please find the below screenshot for your reference.
Hi Britto,
Thanks for your help…but I didnot find any screenshot dear.
