Hello
i want to know how to get financial dimension value thrugh code
let suppose in general ledge module
journal–>general journal–> click on any journal num–>in line level–> account and offset account of two ledger dimension values are there and i need those 2 value through code
can any one help me how can i do that?
thanks
Assuming you are referring to Ax2012.
Please refer to the links:http://blogs.msdn.com/b/axsupport/archive/2011/12/21/creating-general-journals-in-ax-2012-in-x.aspx , http://blogs.msdn.com/b/axsupport/archive/2011/10/24/creating-financial-dimension-combinations-in-ax-2012.aspx and white paper Implementing_the_Account_and_Financial_Dimensions_Framework_AX2012 at the link http://download.microsoft.com/download/4/E/3/4E36B655-568E-4D4A-B161-152B28BAAF30/Implementing_the_Account_and_Financial_Dimensions_Framework_AX2012.pdf.
If you are populating dimensions from vendor then you can use the field VendTable.DefaultDimension, this is recID of DimensionAttributeValueSetItem. You will need to find the joins and get the dimension values from few tables such as dimensionAttributeValueCombination ,DimensionAttributeValueSetItem ,DimensionAttributeValue, DimensionAttribute .
I am assuming you are referring to Ax2012. Please refer to the links to get insight on how to fill in dimensions and create a General Journal in Ax2012 http://blogs.msdn.com/b/axsupport/archive/2011/12/21/creating-general-journals-in-ax-2012-in-x.aspx http://blogs.msdn.com/b/axsupport/archive/2011/10/24/creating-financial-dimension-combinations-in-ax-2012.aspx . http://community.dynamics.com/ax/f/33/t/67891.aspx
The value stored in LedgerJournalTrans.LedgerDimension is the recID of dimensionAttributeValueCombination
If you are populating the dimensions from vendor then you may use VendTable.DefaultDimension field. This is a recID of DimensionAttributeValueSet. This is same with CustTable.DefaultDimension. Look at the joins between the tables : ledgerJournalTrans, dimensionAttributeValueCombination,DimensionAtributeValueSetItem,DimensionAttributeValue,DimensionAttribute to get the display value used in the dimenisions.
