Type conversion is not possible because 1 of the operators contains an invalid type.
Hi
I got my solution.
Try
if (Address2 <> ‘’) or (OverLimitMsg <> ‘’ )then begin
Hi Srikanth,
Please share your solution also with us not only problems/questions [Y]
Thanks.
Hi Manish,
Thanks for Reply, and one more Problem in this:
Blocked data type is Option
EnterCell(i,4,Customer.Blocked,FALSE,FALSE,FALSE,’’,’’);
Problem is:
Microsoft Dynamics NAV Classic
Text := Option
OK
Did you try FORMAT(Customer.Blocked) in above code?
Hi Mohana
I tried that but no use
What do you mean by no use?
are you still getting error?
I got Solution.
Solution is:
CASE Customer.Blocked OF
Customer.Blocked :
EnterCell(i,4,‘Ship’,FALSE,FALSE,FALSE,’’,’’);
Customer.Blocked ::Invoice:
EnterCell(i,4,‘Invoice’,FALSE,FALSE,FALSE,’’,’’);
Customer.Blocked ::All:
EnterCell(i,4,‘All’,FALSE,FALSE,FALSE,’’,’’);
ELSE
EnterCell(i,4,’ ‘,FALSE,FALSE,FALSE,’’,’’);
END;
What Mohana is saying, is that you don’t need your CASE statement, you can just as well replace it all with one line:
EnterCell(i,4,FORMAT(Customer.Blocked),FALSE,FALSE,FALSE,'','');
