In General Journal I have created two lines when I post these line give the error message error is-
Page 39 General Journal contains several Actions with the same ID -100.
Redesign the page to remove duplicate Action IDs.
why this error come from posting and also post and print button shows the same error.
hi Sunil,
You an error on this Page 39 . Look at Page Actions and their IDs some of them have duplication …
Just as it says . Its a developer/consultant task…
gabor
I delete the object(Page 39) which give the error and import the standard object then I open the page gives the again same error,
Which NAV version are you running?
Can you please check in User Metadata table filtering for page 29 if there is any record? In case delete the record, compile the page again and retry.
