Sporadic Metadata Error when pushing action button on page, in this case when trying to post a warehouse shipment. When user exist page and reloads, they post it without errors:
“Metadata for page 7335 does not contain a control definition for the control with ID -208.”
I’ve tried recompiling the ‘said’ page but users still has issues.
Well basically with any metadata issues, then you should always start by recompiling the objects as you also did. But it could also be if the user made some personalizations/customizations to it. So check if that is the case. If yes, you could try to remove it for that user.
I actually just found a link (in Danish) which explains this error as a sporadic error that was fixed in NAV 2016 CU9. That’s the CU that was released this week.
Didn’t have the error my self, so could test if it solves it. But try to upgrade to NAV 2016 CU9.
