On the Options tab of the Alter Database window, you can change any of the database options that you set when you created the database. For example, you must select the Single User option before carrying out any database tests. You must cancel the selection of this option when the tests are completed.
Single user: If you select this option, only one user can access the database at a time. This setting can be used when you are carrying out administrative functions such as testing or restoring the database. By limiting access to the database to one user, in this case yourself, you ensure that the database is not altered while you are testing it. Remember to clear this check box when you are finished.
there is also one more option in Alter Database Options tab
Members of db_owner, dbcreator or sysadmin: If you select this option, only members of the db_owner fixed database role, the dbcreator fixed server role or the sysadmin fixed server role have access to the database.
