Dhanan
April 7, 2011, 12:55pm
1
Hello Guys,
I am working on NAV 2009 , I am geeting error while posting Purchase order.
The process flow is as follows:-
Item having costing method as : Specific
with item tracking true for serial number
Then step one is create sales order then create purchase order
then assign serial number on PO then i am try to post
while posting it shows as error " Item Tracking does not match "
Kindly provide me solution for this.
Thanks in advance
rgds
dhananjay
Is there any reservation between Sales Order and Purchase Order?
I hope system may take serial number automatically to the purchase order
Dhanan
April 7, 2011, 1:28pm
4
There is no reservation between Sales order and Purchase order.
rgds
dhananjay
Dhanan
April 7, 2011, 1:31pm
5
Ya system will assign serial number on purchase order automatically if we define number series.
But while posting it shows an error that Item tracking does not match.
Does system checking same sr. number for Sales order also?
rgds
dhananjay
Then I am not able to replicate your error as per your steps
BTW, are you using Drop shipment functionality?
Yes, I hope you are using drop shipment functionality
you need to synchronize the Item tracking lines from Purchase Order
Dhanan
April 8, 2011, 5:25am
9
I am not using Drop shipment functionality.
We had done small customization on sale order that from sales order you can create Purchase requisition and from Purch req. you can create PO this is normally out of ox available.
So i have to assign the sr. number on PO then I am trying to post it at that time it shows an error that " Item tracking does not match"
I think it is checking the sr. no on sales order also.
rgds
dhananjay
Yes, it will check when you have sa;es order no in your purchase line…
@Dhananjay ,
Yes The system will check the same serial number for sales order also
Dhanan
April 8, 2011, 6:29am
12
So in that case we have to flow same serial number on the related sales order.
If this is done then will the problem is resolve?
rgds
dhananjay
Yes…you just select the same Serial no as purchase line in sales line
@Dhananjay ,
Yes correct, u try for that. then ur problem solved
Dhanan
April 8, 2011, 8:01am
15
Yes we had done that and now we are able to post.
In case of Drop shipment condiiton it will check item reservation entry.
So we insert one additional condition on the item resrvation. then our problem is resolve.
thanks for your valuable inputs.
rgds
dhananjay
