I have the following problem when tryint to post a sales invoice.
I generate an invoice from Job Planning Lines of a contract. All lines a type “Contract” and are Products. From Jobs/View Job Planning Lines I excute the “Create sales invoice” action. After that, a new invoice is created and all “contract” lines are marked as transferred and the Invoice No. is correctly filled.
When I open the Invoice and are trying to post it, I get following message:
“You should consume Item in Job before you post sales invoice”
As the message says: you have to consume before invoicing.
You consume items via Jobs → “Job Journals”. What is done here is that a negative adjustment is made on the item and “kind of” a positive adjustment on the job. You actually move stock from inventory to job.
You can never invoice more from a job than you have consumed.
finally I changed all Job Planning Lines from “Contract” to “Schedule and Contract”. That allows me to post product usage and later post the sales invoice!
Please, if any of the replies to your post solved your problem, then please click on the “Verify solution” next to that post. This way we can see that you post is closed and you got the help you needed.
