While making report I got stucked into a small issue for not getting any solution for it. Can anyone help me for solving this issue.
Firstly I want to select the maximum purchase Order Id from the table VendPurchOrderJour.
And after getting the max purchaseorde id for the same Purch Id ,I want to select all the items related to this max purchaseOrderId from the table VendPurchseOrderTrans.
For this I have also written code which is correctly running in job but not giving correct output in report as only returning the last value.
Thanx Enrique for the reply.Actually what I want to do is : I have to show in the report only those items which is get posted recently .And I can collect it from VendPurchOrderJour which has been here as 00000011_070 when i am selecting for the purch id 00000062_069.
After getting the max Purchase Order Id from table VendPurchOrderJour .I want to select only those items from the table VendPurchOrderTrans whose PurchaseOrderId==00000011_070
I want to show the items from 1.01 to 141.O1 i.e last 12 items in the report .How i can do this?
The method which I have posted in the question is running correctly in the job and all the items are getting printed on the screen but when I use the same method in the report it not showing all the items,only it is returning the first value .
The method u have written is same as the the one I have tried but the items are not getting printed on the report.
Can u post the complete code which u have used in your fetch method… See, put a debugger and check what is happening and what is the execution flow. So u can able to find why only the first item in printed and why it is not goin to the next item…
How can you run a report with display method… As jyothi says, it will return only one value means, one cycle of data. Fetch method is the right method to code for a report in the case the requirement u needs. thats y i asked you what code u have written in ur fetch method. Every cycle, if u need the display data which is not in your datasource, at that time, create a temp buffer or variable, store the data and display that data in display method.
