respected all,
when i am running the report following error through. anybody have solution please let me know.
Error:
Error executing code: Array index 8 is out of bounds.
Stack trace
(S)\Classes\CustVendBalanceList\insertAgingBucket - line 34
(S)\Classes\CustVendBalanceList\new - line 28
(S)\Classes\CustVendBalanceList\construct - line 29
(S)\Reports\CustAgingReport\Methods\fetch
(S)\Classes\ReportRun\run
(S)\Classes\SysReportRun\run - line 26
(S)\Classes\RunBaseReport\run - line 34
(S)\Classes\SysReportRun\run - line 15
(S)\Classes\MenuFunction\runServer
Hi
I am facing same issue in customer aging report.If you get the solution please reply me.
Thanks in advance
Usually caused by a customization of sorts, ensure any changes compile to best practice and failing this get a developer to investigate.
Hi AdamRoue
Thnx for quick reply.I am trying to add more columns to display report month wise.It is not showing Any error and warnings while compiling.
And if you restore it back then you will not get the errors - so your additional columns are causing the issue, you are designing beyond what is allowed I guess from the message. Talk to a developer, I am not one [:D]
hello narasimha…
i havent received any solution so that i was create new report and solve my problem.
thanks & regards
Thanks For all for quick reply.
I AM LOOKING JOB CHANGE AND PREFER IN GUJARAT.
I AM INTERESTED IN NON IT COMPANIES SO IF YOU HAVE ANY CONTACT IN YOU CUSTOMER LIST THEN PLEASE LET ME KNOW SIR,
