I have been trying to install EP (ax2009 + sp1 + moss2007 + Sp2). I keep receving a warning when I finish the EP Installation. I tried recompile the SysDevelopmentProxy class or recomplie the all classes. but it doesn’t work…Someone help please. installation log is as below.
=== Setup logging started: 9/1/2012 4:38:31 PM ===
Running file: “C:\Users\ADMINI~1\AppData\Local\Temp\AxSetup\AxSetup.exe” RelatedFilesDir=“E:\DynamicsAX2009”
AxSetup version number: 5.0.593.0
Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit)
WIN-56AEBQ55EA7
WWW\Administrator
Interactive: True
RelatedFilesDir=E:\DynamicsAX2009
Property RelatedFilesDir set to: ‘E:\DynamicsAX2009’
Property SetupLanguage set to: ‘EN’
=== Loading parameters from the command line or a parameter file ===
Initializing log file: C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2012-09-01 16-38-31\DynamicsSetupLog.txt
=== Starting evaluation of existing installation state ===
Application Object Server instance 1 has been installed with the name 01-AX_Standard.
MSI file: Components64.msi Installed: True
MSI file: ClientHelp.msi Installed: True
Property ClientHelpLanguages set to: ‘EN-US’
Previously Installed Component: Application Object Server (AOS) (01-AX_Standard)
Previously Installed Component: Client
Previously Installed Component: Role Centers and Enterprise Portal
Previously Installed Component: .NET Business Connector
Previously Installed Component: Debugger
Previously Installed Component: Enterprise Portal developer tools
Previously Installed Component: Reporting extensions
Previously Installed Component: Reporting tools
Property RunMode set to: ‘AddRemoveFeatures’
=== Checking parameters ===
Property InstallPath set to: ‘C:\Program Files\Microsoft Dynamics AX\50’
Property InstallPath32Bit set to: ‘C:\Program Files (x86)\Microsoft Dynamics AX\50’
=== Starting UI phase ===
Property RemoveComponents set to: ‘0’
Property BypassWarnings set to: ‘0’
Entering method GetBusinessConnectorProxyAccount
The API return value is www.hamicy.com\axbcproxy.
Leaving method GetBusinessConnectorProxyAccount
Entering method IsRunningMode
The API return value is True.
Leaving method IsRunningMode
Entering method IsUserAnAxAdmin
Leaving method IsUserAnAxAdmin
Property InstallEnterprisePortal set to: ‘1’
Property BusinessConnectorProxyAccount set to: ‘WWW\axbcproxy’
Property BusinessConnectorProxyAccountPassword set to: ‘**********’
Entering function ReadRegKey
Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property AdminServerLocation
Registry Key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0 with Attribute AdminServerLocation has value 1694898283
Leaving function ReadRegKey
Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.GetVirtualServerList
Entering method GetNamesOfAllWebSites
Leaving method GetNamesOfAllWebSites
The return value from this method is ‘1,1694898283,951338967,1364556691’.
Entering method GetWebSite
The input parameters to this method are: ‘1’
Leaving method GetWebSite
The return value from this method is ‘1’.
The input parameters to this method are: ‘1694898283’
The return value from this method is ‘1694898283’.
Entering method GetFriendlyNameOfWebSite
Leaving method GetFriendlyNameOfWebSite
The return value from this method is ‘SharePoint Central Administration v3’.
Entering method GetPortNumberOfWebSite
Leaving method GetPortNumberOfWebSite
The return value from this method is ‘47807’.
Entering method GetWebSiteHomeDirectory
Entering method DoesWebSiteExist
Leaving method DoesWebSiteExist
The return value from this method is ‘True’.
Entering method GetRootVirtualDirMetabasePath
Leaving method GetRootVirtualDirMetabasePath
The return value from this method is ‘IIS://localhost/W3SVC/1694898283/Root’.
Leaving method GetWebSiteHomeDirectory
The return value from this method is ‘C:\inetpub\wwwroot\wss\VirtualDirectories\45756’.
Entering method GetFirstHostHeaderOfWebSite
Leaving method GetFirstHostHeaderOfWebSite
The return value from this method is ‘’.
The input parameters to this method are: ‘951338967’
The return value from this method is ‘951338967’.
The return value from this method is ‘Office Server Web Services’.
The return value from this method is ‘56737’.
The return value from this method is ‘IIS://localhost/W3SVC/951338967/Root’.
The return value from this method is ‘C:\Program Files\Microsoft Office Servers\12.0\WebServices\Root’.
The input parameters to this method are: ‘1364556691’
The return value from this method is ‘1364556691’.
The return value from this method is ‘SharePoint - 22818’.
The return value from this method is ‘22818’.
The return value from this method is ‘IIS://localhost/W3SVC/1364556691/Root’.
The return value from this method is ‘C:\inetpub\wwwroot\wss\VirtualDirectories\22818’.
Setup found 3 virtual servers.
Virtual server Office Server Web Services, Port: 56737, Path: C:\Program Files\Microsoft Office Servers\12.0\WebServices\Root
Virtual server SharePoint - 22818, Port: 22818, Path: C:\inetpub\wwwroot\wss\VirtualDirectories\22818
Leaving function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.GetVirtualServerList
Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.DefaultEnterprisePortalWebSiteURL
Virtual server: Office Server Web Services
Entering function ValidateVirtualServer
Leaving function ValidateVirtualServer
Entering function GetVirtualServerURL
http://WIN-56AEBQ55EA7:56737
Leaving function GetVirtualServerURL
Entering function GetEPSiteURL
Entering function LoadEPSetupParams
Entering function StaticFileContents
EP Site
/DynamicsAx
Leaving function LoadEPSetupParams
SPPrefixType.WildcardInclusion: sites
http://WIN-56AEBQ55EA7:56737/sites/DynamicsAx
Leaving function GetEPSiteURL
Leaving function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.DefaultEnterprisePortalWebSiteURL
Virtual server: SharePoint - 22818
http://WIN-56AEBQ55EA7:22818
http://WIN-56AEBQ55EA7:22818/sites/DynamicsAx
Property EnterprisePortalWebSite set to: ‘SharePoint - 22818’
Property EnterprisePortalCreateWebSite set to: ‘1’
Property EnterprisePortalConfigureForWss set to: ‘1’
Property ResetIIS set to: ‘1’
=== Starting execution phase ===
=== Setting up ASP.NET 2.0 ===
Configuring the .NET Framework ASP.Net for IIS
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\aspnet_regiis.exe -i -enable
Finished installing ASP.NET (2.0.50727).
C:\Windows\Microsoft.NET\Framework64\v2.0.50727\aspnet_regiis.exe -sn W3SVC
Start registering ASP.NET scriptmap (2.0.50727) at W3SVC.
Finished registering ASP.NET scriptmap (2.0.50727) at W3SVC.
=== Setting up Components ===
Launching MSI: /i “E:\DynamicsAX2009\Msi\Components64\Components64.msi” /qb-! /l*v “C:\ProgramData\Microsoft\Dynamics AX\Dynamics AX Setup Logs\2012-09-01 16-38-31\Components64 Log.txt” DIRECTEXECUTE=1 SETUPLANGUAGE=EN INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\50” INSTALLDIR32=“C:\Program Files (x86)\Microsoft Dynamics AX\50” ADDLOCAL=“ClientUI,EnterprisePortal,NetBusinessConnector,Debugger,EnterprisePortalTools,ReportingServicesExtensions,ReportingTools,ClientConfig”
Starting configuration of Role Centers and Enterprise Portal
Entering function Microsoft.Dynamics.Framework.Deployment.Portal.IEPDeployment.InstallEnterprisePortal
virtual server: ‘SharePoint - 22818’; Business Connector proxy account ‘WWW\axbcproxy’; Configure for Windows SharePoint Services: True; Restart IIS: True; Create Web site: True
Entering method SetBCProxyAccountInAxapta
The API input parameter is WWW\axbcproxy.
Entering method UpdateBusinessConnectorProxyAccount
Leaving method UpdateBusinessConnectorProxyAccount
Setup updated the .NET Business Connector proxy account WWW\axbcproxy in Microsoft Dynamics AX.
Leaving method SetBCProxyAccountInAxapta
Setup determined that virtual server SharePoint - 22818 is already extended in SharePoint.
Entering method GetAppPoolIdProperty
Leaving method GetAppPoolIdProperty
The return value from this method is ‘SharePoint_22818_712c26cb4b1b400c91c539c2b25e5745’.
Entering method GetAppPoolIdentity
The input parameters to this method are: ‘SharePoint_22818_712c26cb4b1b400c91c539c2b25e5745’
Leaving method GetAppPoolIdentity
The return value from this method is ‘WWW\axbcproxy’.
The virtual server SharePoint - 22818 is associated with application pool SharePoint_22818_712c26cb4b1b400c91c539c2b25e5745. The application pool is running under WWW\axbcproxy.
Entering function CompareUserAccounts
Entering function ConvertUserAccountToFullyQualifiedDomainNameAccount
Converting user account WWW\axbcproxy to a fully qualified domain name
Setup converted the user account WWW\axbcproxy to the fully qualified domain name www.hamicy.com\axbcproxy.
Leaving function ConvertUserAccountToFullyQualifiedDomainNameAccount
Leaving function CompareUserAccounts
The application pool SharePoint_22818_712c26cb4b1b400c91c539c2b25e5745 associated with virtual server SharePoint - 22818 is already running under the .NET Business Connector proxy account WWW\axbcproxy. Updating the credentials for the application pool
Entering function ConfigureApplicationPool
Leaving function InstallEnterprisePortal
Entering function ConfigureAuthenticationMode
Entering function RemoveOldWebPartPackage
Entering function GetEPVirtualServers
Entering function FindSolutionInFarm
Solution axwebparts.cab exists in the server farm.
Leaving function FindSolutionInFarm
Entering function WebApplicationFromUrl
Entering function AdminPortIisInstanceId
Entering function Remove40WPPackage
Entering function Is40WPPackageInstalled
Microsoft Dynamics AX 4.0 Web Part package axwebparts.cab installation status False
Leaving function Is40WPPackageInstalled
Leaving function Remove40WPPackage
Leaving function RemoveOldWebPartPackage
Could not load file or assembly ‘Microsoft.Dynamics.AX.Fim.PaymentService, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified.
at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.AppDomain.Load(String assemblyString)
at ClrBridgeImpl.LoadAssembly(ClrBridgeImpl* , Char* assemblyName)
at ClrBridgeImpl.GetTypes(ClrBridgeImpl* , Char* assemblyName, Boolean* isException)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Workflow.Communication, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified.
Could not load file or assembly ‘Microsoft.Dynamics.Kernel.Client, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified.
Could not load file or assembly ‘Microsoft.Dynamics.ReportingServices, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified.
Could not load file or assembly ‘Microsoft.Dynamics.RfidProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified.
Could not load file or assembly ‘Microsoft.Dynamics.SysImport, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified.
Could not load file or assembly ‘Microsoft.Dynamics.TeamFoundationServerProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified.
Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\12.0, property Location
Reading registry key SOFTWARE\Microsoft\Dynamics\5.0\Setup, property InstallDir
Entering method deployEPOnSharepoint
Deploying Static files…
Entering function StoreStaticFileName
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts\ep\ActivityDeleteConfirmationDialog.aspx’ in the install information file.
Leaving function _InvokeMethodFast
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts\ep\ActivityDeleteConfirmationDialog.aspx.cs’ in the install information file.
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts\ep\stylesheets\AXEP_CRC.css’ in the install information file.
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts\ep\stylesheets\AXEP_CRC_RTL.css’ in the install information file.
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts\ep\stylesheets\AXEP_RTL.css’ in the install information file.
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts\ep\stylesheets\AXEP_WebPart_Padding.css’ in the install information file.
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts\ep\axepexport.aspx’ in the install information file.
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts…\Features\DynamicsAxEnterprisePortal\elements.xml’ in the install information file.
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts…\Features\DynamicsAxEnterprisePortal\Feature.xml’ in the install information file.
Storing file ‘C:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\layouts…\Features\DynamicsAxDataConnection\Feature.xml’ in the install information file.
Le
