Hi friends,
I add web part(which is developed visual studio 2008) in enterprise portal website.i get following error.I place only controls to add that.but when i place the code in axgenerals.ascx.cs(file name) i get this error.
An unexpected error has occurred.
System.Web.HttpCompileException: c:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\LAYOUTS\ep\axgenerals.ascx.cs(11): error CS0234: The type or namespace name ‘BusinessConnectorNet’ does not exist in the namespace ‘Microsoft.Dynamics’ (are you missing an assembly reference?)
at System.Web.Compilation.BuildManager.PostProcessFoundBuildResult(BuildResult result, Boolean keyFromVPP, VirtualPath virtualPath)
at System.Web.Compilation.BuildManager.GetBuildResultFromCacheInternal(String cacheKey, Boolean keyFromVPP, VirtualPath virtualPath, Int64 hashCode)
at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
at System.Web.UI.TemplateControl.LoadControl(VirtualPath virtualPath)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxContentPanel.LoadHostedControl()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxContentPanel.AddHostedControl()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.AxContentPanel.OnInit(EventArgs e)
at System.Web.UI.Control.InitRecursive(Control namingContainer)
at System.Web.UI.Control.AddedControl(Control control, Int32 index)
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.WebParts.AxBaseWebPart.AddContentPanel()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.WebParts.AxUserControlWebPart.CreateChildControls()
at System.Web.UI.Control.EnsureChildControls()
at Microsoft.Dynamics.Framework.Portal.UI.WebControls.WebParts.AxBaseWebPart.OnInit(EventArgs e)
at System.Web.UI.WebControls.WebParts.WebPartManager.WebPartManagerControlCollection.AddWebPartHelper(WebPart webPart)
at System.Web.UI.WebControls.WebParts.WebPartManager.WebPartManagerControlCollection.AddWebPart(WebPart webPart)
at System.Web.UI.WebControls.WebParts.WebPartManagerInternals.AddWebPart(WebPart webPart)
at Microsoft.SharePoint.WebPartPages.SPWebPartManager.AddWebPartWithRetry(WebPart webPart)
at Microsoft.SharePoint.WebPartPages.SPWebPartManager.AddDynamicWebPart(WebPart webPart)
at Microsoft.SharePoint.WebPartPages.SPWebPartManager.CreateWebPartsFromRowSetData(Boolean onlyInitializeClosedWebParts)
at Microsoft.SharePoint.WebPartPages.SPWebPartManager.LoadWebParts()
at Microsoft.SharePoint.WebPartPages.SPWebPartManager.OnPageInitComplete(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Web.UI.Page.OnInitComplete(EventArgs e)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
i used the following namespaces
using System;
using System.Collections;
using System.Web;
using System.Web.Security;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.UI.WebControls.WebParts;
using System.Web.UI.HtmlControls;
using Microsoft.Dynamics.Framework.Portal.UI.WebControls;
using Microsoft.Dynamics.Framework.Portal.UI.WebControls.WebParts;
using Microsoft.Dynamics.BusinessConnectorNet;
using Microsoft.Dynamics.Framework.BusinessConnector.Session;
Please help this
