EP Web Control Error in ax2009
HI All , I am facing the following error while EP Development in ax2009.
An unexpected error has occurred. c:\Program Files\Common Files\Microsoft Shared\Web Server Extensions\12\TEMPLATE\LAYOUTS\ep\AMITimesheet.ascx.cs(12): error CS0234: The type or namespace name ‘Linq’ does not exist in the namespace ‘System.Xml’ (are you missing an assembly reference?)
Thanks in Advance.
I got the solution.
Thank u all.
Hello,
Sorry had to unmark your above post as solution because this doesn’t tell us anything.
Please can you tell us in detail how you managed to resolve this issue?
