Hi guys,
I am getting the following erro when installing EP in AX2012:
Assembly containing type System.Xml.XmlTextWriter is not referenced.
Here is part of the error log, starting from just before the error:
2013-03-28 13:15:05Z Entering function FindSolutionInFarm
2013-03-28 13:15:05Z Leaving function FindSolutionInFarm
2013-03-28 13:15:05Z Leaving function RemoveOldWebPartPackage
2013-03-28 13:15:10Z Reading registry key SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\14.0, property Location
2013-03-28 13:15:16Z Setup encountered an error during deployment of the Role Center and Enterprise Portal framework.
2013-03-28 13:15:16Z Entering method deployEPOnSharepoint
2013-03-28 13:15:16Z Deploying Static files…
2013-03-28 13:15:16Z Assembly containing type System.Xml.XmlTextWriter is not referenced.
2013-03-28 13:15:16Z Object ‘CLRObject’ could not be created
2013-03-28 13:15:16Z Microsoft.Dynamics.Framework.BusinessConnector.Session.Exceptions.XppSessionException
2013-03-28 13:15:16Z at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsSession.HandleException(String message, Exception exception, HandleExceptionCallback callback)
2013-03-28 13:15:16Z at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsObjectAdapter.Call(String methodName, Object param1, Object param2)
2013-03-28 13:15:16Z at Microsoft.Dynamics.Framework.BusinessConnector.Proxy.SysEPDeployment.installEnterprisePortal(String virtualServerUrl, Boolean developerInstall)
2013-03-28 13:15:16Z at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.DeployEnterprisePortal(String virtualServerUrl, Boolean developerInstall)
2013-03-28 13:15:16Z Microsoft.Dynamics.AX.ManagedInterop.InternalException
2013-03-28 13:15:16Z at Microsoft.Dynamics.AX.ManagedInterop.Object.CallWithReturnType(String methodName, Type returnType, Object[] paramList)
2013-03-28 13:15:16Z An error occurred during setup of Enterprise Portal (EP).
2013-03-28 13:15:16Z Reason: Setup encountered an error during deployment of the Role Center and Enterprise Portal framework.
2013-03-28 13:15:16Z Registering tracing manifest file “C:\Program Files\Microsoft Dynamics AX\60\Server\Common\TraceProviderCrimson.man”.
2013-03-28 13:15:16Z WEvtUtil.exe install-manifest “C:\Users\AXAdmin\AppData\Local\Temp\tmpDBF.tmp”
2013-03-28 13:15:16Z **** Warning: Publisher {8e410b1f-eb34-4417-be16-478a22c98916} is installed on
2013-03-28 13:15:16Z the system. Only new values would be added. If you want to update previous
2013-03-28 13:15:16Z settings, uninstall the manifest first.
2013-03-28 13:15:16Z Tracing manifest file has been registered successfully.
2013-03-28 13:15:16Z === Rolling back setup of Enterprise Portal (EP) due to error ===
2013-03-28 13:15:16Z Running Msiexec.exe with these parms: /i “C:\Altair\AX Setup Files\MSI\Components64\Components64.msi” /qb! /l*v “C:\Program Files\Microsoft Dynamics AX\60\Setup Logs\2013-03-28 13-12-59\Components64 Rollback Log.txt” DIRECTEXECUTE=1 /norestart PATCH=“C:\Altair\AX Setup Files\Updates\DynamicsAX2012-KB2606916\MSI\Components64\Components64.msp;C:\Altair\AX Setup Files\Updates\DynamicsAX2012-KB2650968\MSI\Components64\Components64.msp” INSTALLDIR=“C:\Program Files\Microsoft Dynamics AX\60” INSTALLDIR32=“C:\Program Files (x86)\Microsoft Dynamics AX\60” ADDLOCAL=“EnterprisePortal,ModelManagement,ClientConfig” REMOVE=“EnterprisePortal”
2013-03-28 13:15:16Z Running synchronously.
2013-03-28 13:16:39Z === Rolling back setup of Enterprise Portal (EP) due to error ===
2013-03-28 13:16:39Z The Rollback has been completed. For details about why the installation failed, see the previous messages in the log.
2013-03-28 13:16:39Z ******************************************************************************************************
2013-03-28 13:16:39Z Component installation task stopped due to an error.
I have seen another request for help on this error, but there was no answer.
Has anyone seen this? How do I add the reference to make it work?
Thanks in advance,
David
