When posting Sales Invoice i get this error “posting date is not with in your range”.
*User posting date set 08/01/16…08/31/16
*G/L Setup date set 09/01/16…09/30/16
*Invoice Posting date 08/20/16
Please i tried to look into this issue and no solution. and i noticed this issue mostly surfacing at the end of the month after adjust cost batch job run.
I didn’t field invoice date 082016 (08/20/16?) in g/l setup or user setup.
can you check again please.
please activate the debugger to check exact place of error and values available there.
Ok, then you’r right, then it looks like something is wrong.
And I assume that the user who gets this error is the user with the date setup?
Then I would follow Mohana’s suggestion. Run it with the debugger activated, then it will stop exactly where the error occurs, and here you can see why it didn’t check the users date setup.
Hello everybody
I followed your suggestion and the debugger traced the error on Code unit 21
CheckAllowedPostingDate(ItemJnlLine : Record “Item Journal Line”)
WITH ItemJnlLine DO BEGIN
IF (AllowPostingFrom = 0D) AND (AllowPostingTo = 0D) THEN BEGIN
InvtSetup.GET;
GLSetup.GET;
IF USERID <> ‘’ THEN
IF UserSetup.GET(USERID) THEN BEGIN
AllowPostingFrom := UserSetup.“Allow Posting From”;
AllowPostingTo := UserSetup.“Allow Posting To”;
END;
AllowPostingFrom := GLSetup.“Allow Posting From”;
AllowPostingTo := GLSetup.“Allow Posting To”;
END;
IF AllowPostingTo = 0D THEN
AllowPostingTo := 31129999D;
END;
IF (“Posting Date” < AllowPostingFrom) OR (“Posting Date” > AllowPostingTo) THEN
FIELDERROR(“Posting Date”,Text001)//Right here
END;
What would be the case since my Posting date on the invoice falls between the date range given for the user??
Is Automatic cost posting is ticked in Inventory setup? If Yes then try to remove the tick and post the transactions
As it may be system is trying to post the transaction and adjusting the cost
Hope this helps
Hi Amol
I tried your suggestion and no change.But i am sure when it is trying to post the invoice i see it is bringing the “adjusting value entries Windows” this means it is running adjust cost batch job.If i am not mistaken.
I think you are right the system is trying to adjust inventory during the posting of an invoice and when it tries that it is limited by the user level posting date range.Due to that i have to allow the user posting date further back that he/she supposed to be allowed and where is the posting date limitation use here.It is confused me for long time i hope this thing is a bug in the system and MS has a fix for it.Thank a lot
I have been on many NAV projects where one of the required changes was that absolutely no posts could be done in the old period, after the month was closed. So many you have a similar in your setup?
To what I can see, then NAV has no error in this area. Tried in my own system, works fine here. It’s doing it exactly the way it was designed.
So my guess that the standard code has been changed. Could that be the case?
