Hi Team,
I discovered my NAV 2018 is not working on the browser after I installed as a DEMO and i Checked my IIS under Sites It was not found.
Please help me out, Thanks.
Hi Team,
Dear AYinde,
Can u please check whether your webclient, and webclient dependency installer was installed perfectly or not.
Noramlly after installing the Navision 2018 you will get the option of Dynamics NAV2018 webclient and in IIS also you will get the option of Microsoft dynamics nav 2018 webclient.
So kindly reinstall the webclient from installation folder, then check
Regards
RamakrishnaReddy Y
There was no Web Client for my NAV 2018 in my system. How can I reinstall the webclient
Hai Ayinde,
you have navision 2018 installation files from there there is folder name is called Webclient and webclient dependency installer.
So you need to install these 2 things then you can check.
Regards
RamakrishnaReddy Y
Are you talking about that?
I rerun the setup and i clicked on the add or remove, where i added Web Service.
Hai Ayinde,
So you are issue gone resolved or its still pending.
Regards
RamakrishnaReddy Y
Solved,
