Navision Business Web Service Not Installed On Server
I had installed Nav 2013 R2 On my server.Everything works fine except Navision Business Web Service.
Navision Business Web Service not shown in services.
what can i do ???
How did you installed NAV ?
Through Setup and all components
Installed Demo version or customized ?
There is a web service installed in the dynamics setup folder, did you tried to run that.
I have installed customize version
In dynamics setup folder i have found two setups first is CFiles-MDN-71-Setup and second is setup which setup i can run??
There is a folder named webclient, in that you will find the setup.
Hey Ajay Rastogi
Did you find the solution for the issue.
Hi, i have the same problem and i follow this step but still the same thing any other suggestions plz Thank you
To my knowledge one service does all the jobs, like NAS, WebClient Service, client service.
You can check this in debug page and check there client type.
as i know, the MS Dynamics NAV Business Web Services is mandatory for integration but also normally it must be installed automatically when we install MS Dynamics NAV so i want to know if i can install MS Dynamics NAV Business Web Services or should I uninstall my MS Dynamics NAVE Server and re-install it ? thank you
