1)Can we installed dynamic NAV 2018 and dynamic 365 business central on same server / PC ?
2)I have just installed dynamic 365 business central in my system . Where NAV 2018 was already installed . I am able to open business central NAV client (window client) . But business central web client is not working . It is throwing below error-
HTTP Error 404.0 - Not Found
The resource you are looking for has been removed, had its name changed, or is temporarily unavailable.
Most likely causes:
The directory or file specified does not exist on the Web server.
The URL contains a typographical error.
A custom filter or module, such as URLScan, restricts access to the file.
Things you can try:
Create the content on the Web server.
Review the browser URL.
Create a tracing rule to track failed requests for this HTTP status code and see which module is calling SetStatus. For more information about creating a tracing rule for failed requests, click here.
Can we install Dynamics NAV 2018 and Dynamics 365 Business Central on the same server/PC?
Yes, it is possible to install both Dynamics NAV 2018 and Dynamics 365 Business Central on the same server/PC. However, you need to ensure that:
Both installations use different database instances (e.g., NAV 2018 uses SQL Server 2016, while Business Central uses SQL Server 2017 or later).
Both installations use different web server instances (e.g., NAV 2018 uses IIS 8.5, while Business Central uses IIS 10 or later).
You configure the installations to use different ports and URLs to avoid conflicts.
Business Central web client is not working after installing on a system with NAV 2018 already installed.
The error message you’re seeing (HTTP Error 404.0 - Not Found) suggests that the web client is not configured correctly or is not able to find the requested resource.
Here are some troubleshooting steps you can try:
Check the web client configuration: Ensure that the web client is configured correctly in the Business Central administration center.
Verify the IIS configuration: Check the IIS configuration to ensure that the Business Central web client is configured correctly and is using the correct port and URL.
Check for conflicts with NAV 2018: Ensure that there are no conflicts between the NAV 2018 and Business Central installations, such as port conflicts or database conflicts.
