Hello, i have an issue with document handling on Axapta 2.5 / SP3 2 departments want to store data useing documenthandling, HR and Finance HR shall no be able to see docs of Finance and Finance not on HR. With in Axapta there is no prob, but as docs are stored on fileserver (and DB), they can see each others docs. I only found one place to set a common directory. Or is there any advanced option? Thx Pirmin
Hi If the docs are stored on fileserver, why don’t you modify it so the path is taken depending on the department? Then you can use Windows Security further on.
