Jenna
1
Hi there,
how can i filter the cost center depending on the selected department?
I already created the tree structure, i assigned a department in a ledger account, but when i checked the cost center, all cost centers appeared.
is there a way to filter it?
Thanx a lot!
Jenna
What is your “Active Set” option - In the Ledger Parameters???
Try by Changing it to - At update and Posting…
Jenna
3
Hi Kranthi,
Thank you! I tried it, but didn’t work. Maybe it can’t be filtered. even the demo company, CEU, is like that. Thank you again.
Jenna
In the Dimension Set, go to the General Tab and select the default hierarchy.(which you have created)
Jenna
5
Hi Kranthi,
Huhuhu, it’s still unfiltered.
Indicates that your setup is wrong…
Go through the demo data - where it is working fine…
