when we add new department & new cost center are not apear in seeletable lookup
thanks
thanks
Check for the dimension setting for that particular ledger account. If list is applicable on that ledger then you have to add dimensions on list also.
Also check if advance rule structure is activated or not.
Pranav…
what is advance rule structure ?
