Hi, This is on Navision 4.0. Each item has to have a dimension with same code. Sometimes when new items are entered, users forget to assign dimensions. How can you get the system to warn you if you have not entered a dimension as you add a new item? Thanks Trin
I don’t think this can be done without code. I’ve done such a thing on the job table, but I’ve made some code that creates the dimension automaticaly, this is I think the easiest way to go.
