how to deploy report libraries in ax 2009,when i select deploy on any report library it gives me a message after some time compilation…
the message is… please help me in this regarads,
Could not load file or assembly ‘Microsoft.Dynamics.AX.Fim.PaymentService, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.AppDomain.Load(String assemblyString)
at ClrBridgeImpl.LoadAssembly(ClrBridgeImpl* , Char* assemblyName)
at ClrBridgeImpl.GetTypes(ClrBridgeImpl* , Char* assemblyName, Boolean* isException)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Deployment.Portal, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Portal, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Workflow.Communication, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Kernel.Client, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.ReportingServices, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.RfidProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.SysImport, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.TeamFoundationServerProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Warning: One or more libraries built with warnings. Please see MSBuild log at C:\Users\munsif\AppData\Local\Temp\2\tmpC27.tmp
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DetermineRootFolder at 02:38:31.363
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployForAllCultures at 02:38:31.378
reportLibrariesToDeploy = { ‘[ModelingProjectName = ‘DynamicsReportsLibrary11’, ModelingProjectPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\DynamicsReportsLibrary11.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\bin\Debug\DynamicsReportsLibrary11.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\bin\debug\DynamicsReportsLibrary11.BusinessLogic.dll’]’ }
transitiveReferenceClosure = { ‘[ModelingProjectName = ‘SharedLibrary’, ModelingProjectPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\SharedLibrary.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll’]’, ‘[ModelingProjectName = ‘DynamicsReportsLibrary11’, ModelingProjectPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\DynamicsReportsLibrary11.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\bin\Debug\DynamicsReportsLibrary11.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\bin\debug\DynamicsReportsLibrary11.BusinessLogic.dll’]’ }
logger = ‘Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger’
connectionStringModifier = ‘System.Func2[System.Collections.Generic.IDictionary
2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]' Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.AllAXCultures at 02:38:31.394 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.GetAxCultureIds at 02:38:31.394 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployInTempDomain at 02:38:31.41 reportLibrariesToDeploy = { '[ModelingProjectName = 'DynamicsReportsLibrary11', ModelingProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\DynamicsReportsLibrary11.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\bin\Debug\DynamicsReportsLibrary11.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\bin\debug\DynamicsReportsLibrary11.BusinessLogic.dll']' } transitiveReferenceClosure = { '[ModelingProjectName = 'SharedLibrary', ModelingProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\SharedLibrary.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll']', '[ModelingProjectName = 'DynamicsReportsLibrary11', ModelingProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\DynamicsReportsLibrary11.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\bin\Debug\DynamicsReportsLibrary11.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\bin\debug\DynamicsReportsLibrary11.BusinessLogic.dll']' } cultures = { 'ar', 'cs', 'da', 'de', 'de-AT', 'de-CH', 'en-AU', 'en-CA', 'en-GB', 'en-IE', 'en-IN', 'en-MY', 'en-NZ', 'en-SG', 'en-US', 'en-ZA', 'es', 'es-MX', 'et', 'fi', 'fr', 'fr-BE', 'fr-CA', 'fr-CH', 'hu', 'is', 'it', 'it-CH', 'ja', 'lt', 'lv', 'nb-NO', 'nl', 'nl-BE', 'pl', 'pt-BR', 'ru', 'sv', 'th', 'tr', 'zh-Hans', '' } logger = 'Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger' connectionStringModifier = 'System.Func
2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary
2[System.String,System.String]]’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer+DomainBoundDeployer.Deploy at 02:38:31.957
cultures = { ‘ar’, ‘cs’, ‘da’, ‘de’, ‘de-AT’, ‘de-CH’, ‘en-AU’, ‘en-CA’, ‘en-GB’, ‘en-IE’, ‘en-IN’, ‘en-MY’, ‘en-NZ’, ‘en-SG’, ‘en-US’, ‘en-ZA’, ‘es’, ‘es-MX’, ‘et’, ‘fi’, ‘fr’, ‘fr-BE’, ‘fr-CA’, ‘fr-CH’, ‘hu’, ‘is’, ‘it’, ‘it-CH’, ‘ja’, ‘lt’, ‘lv’, ‘nb-NO’, ‘nl’, ‘nl-BE’, ‘pl’, ‘pt-BR’, ‘ru’, ‘sv’, ‘th’, ‘tr’, ‘zh-Hans’, ‘’ }
2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]' Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DetermineRootFolder at 02:38:32.019 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.Deploy at 02:38:32.597 reportLibrariesToDeploy = { '[ModelingProjectName = 'DynamicsReportsLibrary11', ModelingProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\DynamicsReportsLibrary11.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\bin\Debug\DynamicsReportsLibrary11.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\bin\debug\DynamicsReportsLibrary11.BusinessLogic.dll']' } transitiveReferenceClosure = { '[ModelingProjectName = 'SharedLibrary', ModelingProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\SharedLibrary.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll']', '[ModelingProjectName = 'DynamicsReportsLibrary11', ModelingProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\DynamicsReportsLibrary11.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\bin\Debug\DynamicsReportsLibrary11.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\munsif\AppData\Local\Temp\2\tmp89B.tmp\DynamicsReportsLibrary11\BusinessLogic\bin\debug\DynamicsReportsLibrary11.BusinessLogic.dll']' } cultures = { 'ar', 'cs', 'da', 'de', 'de-AT', 'de-CH', 'en-AU', 'en-CA', 'en-GB', 'en-IE', 'en-IN', 'en-MY', 'en-NZ', 'en-SG', 'en-US', 'en-ZA', 'es', 'es-MX', 'et', 'fi', 'fr', 'fr-BE', 'fr-CA', 'fr-CH', 'hu', 'is', 'it', 'it-CH', 'ja', 'lt', 'lv', 'nb-NO', 'nl', 'nl-BE', 'pl', 'pt-BR', 'ru', 'sv', 'th', 'tr', 'zh-Hans', '' } logger = 'Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger' connectionStringModifier = 'System.Func
Begining deployment on Wednesday, January 22, 2014 2:38:32 AM.
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployBusinessLogicAssemblies at 02:38:32.66
businessLogicAssemblies = { ‘SharedLibrary.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘DynamicsReportsLibrary11.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ }
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 02:38:32.66
assemblies = { ‘SharedLibrary.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘DynamicsReportsLibrary11.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ }
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 02:38:32.675
assembly = ‘SharedLibrary.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 02:38:32.707
assembly = ‘DynamicsReportsLibrary11.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
Thread 9: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateSrsInstance at 02:38:32.785
Error: Deployment failed unexpectedly with the message:
Not found
See the log file for further details.
Deployment failed with the following exception:
System.Management.ManagementException: Not found
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObject.Initialize(Boolean getObject)
at System.Management.ManagementBaseObject.get_Properties()
at System.Management.ManagementBaseObject.GetPropertyValue(String propertyName)
at Microsoft.Dynamics.Framework.Deployment.Reports.SrsWmi.get_InstanceName()
at Microsoft.Dynamics.Framework.Deployment.Reports.WmiUtilities.<>c__DisplayClass1.b__0(SrsWmi s)
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable1 source, Func
2 predicate)
at Microsoft.Dynamics.Framework.Deployment.Reports.WmiUtilities.GetInstalledWmiInstance()
at Microsoft.Dynamics.Framework.Deployment.Reports.WmiUtilities.GetReportServerConfigPath()
at Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployBusinessLogicAssemblies(IEnumerable1 businessLogicAssemblies, DeploymentLogger logger) at Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.Deploy(IEnumerable
1 reportLibrariesToDeploy, IEnumerable1 transitiveReferenceClosure, IEnumerable
1 cultures, DeploymentLogger logger, Func`2 connectionStringModifier)
Assemblies in app domain:
[FullName = ‘AxReports, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.BusinessConnectorNet, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.BusinessConnector, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.Design.Modeling, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.Design.ReportsMetamodel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.Reports, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.ReportsDeployment, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.VisualStudio.Modeling.Sdk, Version=9.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘9.0.30729.4462’]
[FullName = ‘mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘2.0.50727.5420’]
[FullName = ‘msvcm90, Version=9.0.30729.4940, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = null]
[FullName = ‘System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘2.0.50727.5420’]
[FullName = ‘System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.5420’]
[FullName = ‘System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘3.5.30729.5420’]
[FullName = ‘System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.5420’]
[FullName = ‘System.Management, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.5420’]
[FullName = ‘System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.5420’]
[FullName = ‘System.Web.Services, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.5420’]
[FullName = ‘System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘2.0.50727.5420’]
[FullName = ‘System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘2.0.50727.5420’]
The deployment log file can be found at “C:\Users\munsif\AppData\Local\Temp\2\tmp88A.txt”
