Deployment failed unexpectedly error in AX 2009
i am working in ax 2009, when i am trying to deploy ax 2009 SSRS reports facing the following error.
Deployment failed unexpectedly with the message:
Not found
See the log file for further details.
The deployment log file can be found at “C:\Users\Administrator.MMIHYI\AppData\Local\Temp\2\tmpFC21.txt”
Could not load file or assembly ‘Microsoft.Dynamics.AX.Fim.PaymentService, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.AppDomain.Load(String assemblyString)
at ClrBridgeImpl.LoadAssembly(ClrBridgeImpl* , Char* assemblyName)
at ClrBridgeImpl.GetTypes(ClrBridgeImpl* , Char* assemblyName, Boolean* isException)
Could not load file or assembly ‘Microsoft.Dynamics.DataContainer, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Deployment.Portal, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Portal, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Workflow.Communication, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.IntegrationFramework, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Kernel.Client, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.NfeCustServiceModel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Proxy.DataContainers, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.QRCode, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.ReportingServices, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.RfidProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.SyncServices.Library, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.SyncServices.Proxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.SysImport, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.TeamFoundationServerProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DetermineRootFolder at 04:12:02.946
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployForAllCultures at 04:12:02.972
reportLibrariesToDeploy = { ‘[ModelingProjectName = ‘BankSRS’, ModelingProjectPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\BankSRS\BankSRS.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\BankSRS\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\BankSRS\bin\Debug\BankSRS.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll’]’ }
transitiveReferenceClosure = { ‘[ModelingProjectName = ‘SharedComponentsSRS’, ModelingProjectPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\SharedComponentsSRS\SharedComponentsSRS.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\SharedComponentsSRS\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\SharedComponentsSRS\bin\Debug\SharedComponentsSRS.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\SharedComponentsSRS\BusinessLogic\bin\debug\SharedComponentsSRS.BusinessLogic.dll’]’, ‘[ModelingProjectName = ‘SharedLibrary’, ModelingProjectPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\SharedLibrary\SharedLibrary.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll’]’, ‘[ModelingProjectName = ‘BankSRS’, ModelingProjectPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\BankSRS\BankSRS.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\BankSRS\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\BankSRS\bin\Debug\BankSRS.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator.AMIHYD\AppData\Local\Temp\2\tmpFC41.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll’]’ }
logger = ‘Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger’
connectionStringModifier = ‘System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary`2[System.String,System.String]]’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.AllAXCultures at 04:12:02.993
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.GetAxCultureIds at 04:12:02.998
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployInTempDomain at 04:12:03.025
cultures = { ‘ar’, ‘cs’, ‘da’, ‘de’, ‘de-AT’, ‘de-CH’, ‘en-AU’, ‘en-CA’, ‘en-GB’, ‘en-IE’, ‘en-IN’, ‘en-MY’, ‘en-NZ’, ‘en-SG’, ‘en-US’, ‘en-ZA’, ‘es’, ‘es-MX’, ‘et’, ‘fi’, ‘fr’, ‘fr-BE’, ‘fr-CA’, ‘fr-CH’, ‘he’, ‘hu’, ‘is’, ‘it’, ‘it-CH’, ‘ja’, ‘lt’, ‘lv’, ‘nb-NO’, ‘nl’, ‘nl-BE’, ‘pl’, ‘pt-BR’, ‘ru’, ‘sv’, ‘th’, ‘tr’, ‘zh-Hans’, ‘’ }
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer+DomainBoundDeployer.Deploy at 04:12:03.721
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DetermineRootFolder at 04:12:03.782
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.Deploy at 04:12:04.772
Begining deployment on 30 April 2013 16:12:04.
Thread 9: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateSrsInstance at 04:12:04.927
