Report Deployment
I have installed Reporting Tools and Reporting extension and then tried to RUN “AX 2009 Report Deployment.exe” and i get error can anyone give me a solution
The error which i got :
Error: Deployment failed unexpectedly with the message:
Not found
See the log file for further details.
Deployment failed with the following exception:
System.Management.ManagementException: Not found
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObject.Initialize(Boolean getObject)
at System.Management.ManagementBaseObject.get_Properties()
at System.Management.ManagementBaseObject.GetPropertyValue(String propertyName)
at Microsoft.Dynamics.Framework.Deployment.Reports.SrsWmi.get_InstanceName()
at Microsoft.Dynamics.Framework.Deployment.Reports.WmiUtilities.<>c__DisplayClass1.b__0(SrsWmi s)
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable1 source, Func2 predicate)
at Microsoft.Dynamics.Framework.Deployment.Reports.WmiUtilities.GetInstalledWmiInstance()
at Microsoft.Dynamics.Framework.Deployment.Reports.WmiUtilities.GetReportServerConfigPath()
at Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployBusinessLogicAssemblies(IEnumerable1 businessLogicAssemblies, DeploymentLogger logger) at Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.Deploy(IEnumerable1 reportLibrariesToDeploy, IEnumerable1 transitiveReferenceClosure, IEnumerable1 cultures, DeploymentLogger logger, Func`2 connectionStringModifier)
Assemblies in app domain:
[FullName = ‘50urru_d, Version=5.0.0.0, Culture=neutral, PublicKeyToken=null’, assemblyFileVersion = null]
[FullName = ‘AxReports, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.BusinessConnectorNet, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.BusinessConnector, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.Design.Modeling, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.Design.ReportsMetamodel, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.Reports, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.Dynamics.Framework.ReportsDeployment, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’, assemblyFileVersion = ‘5.0.593.0’]
[FullName = ‘Microsoft.VisualStudio.Modeling.Sdk, Version=9.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘9.0.30729.4462’]
[FullName = ‘mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘2.0.50727.4927’]
[FullName = ‘msvcm90, Version=9.0.30729.4926, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = null]
[FullName = ‘System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘2.0.50727.4927’]
[FullName = ‘System.Configuration, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.4927’]
[FullName = ‘System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘3.5.30729.4926’]
[FullName = ‘System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.4927’]
[FullName = ‘System.Management, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.4927’]
[FullName = ‘System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.4927’]
[FullName = ‘System.Web.Services, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a’, assemblyFileVersion = ‘2.0.50727.4927’]
[FullName = ‘System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘2.0.50727.4927’]
[FullName = ‘System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089’, assemblyFileVersion = ‘2.0.50727.4927’]
Thank you in Advance
check once
sql server 2005 reporting services install or not
the Sql Server 2005 is not Installed… I Did the ax installation with SQL server 2008 R2.
I think the solution might be resolved installing the software named ‘windows sdk’ …
Search in the google with the following keyword “windows sdk for windows server 2008 r2 and .net framework 3.5” if you are using windows server 2008 r2.
Thank you Lalit.
I tried to install the SDK like you said but still ending up with the same error[:@]
After installing that sdk,have you tried to run that report deployment wizard ??
If no then do it…
Ya Lalit i did try it. I get this error when i run the wizard.
Can you share the log file created while running this application ?
It may contain the cause for this error and after that we can find the proper resolution for it.
This is the log file:
Could not load file or assembly ‘Microsoft.Dynamics.AX.Fim.PaymentService, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.AppDomain.Load(String assemblyString)
at ClrBridgeImpl.LoadAssembly(ClrBridgeImpl* , Char* assemblyName)
at ClrBridgeImpl.GetTypes(ClrBridgeImpl* , Char* assemblyName, Boolean* isException)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Deployment.Portal, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Framework.Workflow.Communication, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.Kernel.Client, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.ReportingServices, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.RfidProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.SysImport, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.TeamFoundationServerProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DetermineRootFolder at 08:47:38.749
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployForAllCultures at 08:47:39.05
reportLibrariesToDeploy = { ‘[ModelingProjectName = ‘Vend’, ModelingProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\Vend.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\bin\Debug\Vend.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\bin\debug\Vend.BusinessLogic.dll’]’ }
transitiveReferenceClosure = { ‘[ModelingProjectName = ‘SharedLibrary’, ModelingProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\SharedLibrary.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll’]’, ‘[ModelingProjectName = ‘Vend’, ModelingProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\Vend.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\bin\Debug\Vend.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\bin\debug\Vend.BusinessLogic.dll’]’ }
logger = ‘Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger’
connectionStringModifier = ‘System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]' Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.AllAXCultures at 08:47:39.073 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.GetAxCultureIds at 08:47:39.075 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployInTempDomain at 08:47:39.124 reportLibrariesToDeploy = { '[ModelingProjectName = 'Vend', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\Vend.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\bin\Debug\Vend.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\bin\debug\Vend.BusinessLogic.dll']' } transitiveReferenceClosure = { '[ModelingProjectName = 'SharedLibrary', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\SharedLibrary.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll']', '[ModelingProjectName = 'Vend', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\Vend.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\bin\Debug\Vend.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\bin\debug\Vend.BusinessLogic.dll']' } cultures = { 'ar', 'cs', 'da', 'de', 'de-AT', 'de-CH', 'en-AU', 'en-CA', 'en-GB', 'en-IE', 'en-IN', 'en-MY', 'en-NZ', 'en-SG', 'en-US', 'en-ZA', 'es', 'es-MX', 'et', 'fi', 'fr', 'fr-BE', 'fr-CA', 'fr-CH', 'hu', 'is', 'it', 'it-CH', 'ja', 'lt', 'lv', 'nb-NO', 'nl', 'nl-BE', 'pl', 'pt-BR', 'ru', 'sv', 'th', 'tr', 'zh-Hans', '' } logger = 'Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger' connectionStringModifier = 'System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer+DomainBoundDeployer.Deploy at 08:47:39.766
cultures = { ‘ar’, ‘cs’, ‘da’, ‘de’, ‘de-AT’, ‘de-CH’, ‘en-AU’, ‘en-CA’, ‘en-GB’, ‘en-IE’, ‘en-IN’, ‘en-MY’, ‘en-NZ’, ‘en-SG’, ‘en-US’, ‘en-ZA’, ‘es’, ‘es-MX’, ‘et’, ‘fi’, ‘fr’, ‘fr-BE’, ‘fr-CA’, ‘fr-CH’, ‘hu’, ‘is’, ‘it’, ‘it-CH’, ‘ja’, ‘lt’, ‘lv’, ‘nb-NO’, ‘nl’, ‘nl-BE’, ‘pl’, ‘pt-BR’, ‘ru’, ‘sv’, ‘th’, ‘tr’, ‘zh-Hans’, ‘’ }
connectionStringModifier = ‘System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]' Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DetermineRootFolder at 08:47:39.816 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.Deploy at 08:47:40.499 reportLibrariesToDeploy = { '[ModelingProjectName = 'Vend', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\Vend.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\bin\Debug\Vend.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\bin\debug\Vend.BusinessLogic.dll']' } transitiveReferenceClosure = { '[ModelingProjectName = 'SharedLibrary', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\SharedLibrary.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll']', '[ModelingProjectName = 'Vend', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\Vend.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\bin\Debug\Vend.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\1\tmp4D34.tmp\Vend\BusinessLogic\bin\debug\Vend.BusinessLogic.dll']' } cultures = { 'ar', 'cs', 'da', 'de', 'de-AT', 'de-CH', 'en-AU', 'en-CA', 'en-GB', 'en-IE', 'en-IN', 'en-MY', 'en-NZ', 'en-SG', 'en-US', 'en-ZA', 'es', 'es-MX', 'et', 'fi', 'fr', 'fr-BE', 'fr-CA', 'fr-CH', 'hu', 'is', 'it', 'it-CH', 'ja', 'lt', 'lv', 'nb-NO', 'nl', 'nl-BE', 'pl', 'pt-BR', 'ru', 'sv', 'th', 'tr', 'zh-Hans', '' } logger = 'Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger' connectionStringModifier = 'System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]’
Begining deployment on Monday, August 20, 2012 8:47:40 AM.
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateSrsInstance at 08:47:40.664
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployBusinessLogicAssemblies at 08:47:40.684
businessLogicAssemblies = { ‘SharedLibrary.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘Vend.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ }
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 08:47:40.693
assemblies = { ‘SharedLibrary.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘Vend.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ }
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 08:47:40.747
assembly = ‘SharedLibrary.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 08:47:40.803
assembly = ‘Vend.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 08:47:40.806
Not found
The deployment log file can be found at “C:\Users\Administrator\AppData\Local\Temp\1\tmp4D24.txt”
Thank You Lalit
This is the log file :
Not found
Thank you Lalit.
Not found
Warning: One or more libraries built with warnings. Please see MSBuild log at C:\Users\Administrator\AppData\Local\Temp\tmp9711.tmp
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DetermineRootFolder at 12:15:26.037
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployForAllCultures at 12:15:26.089
reportLibrariesToDeploy = { ‘[ModelingProjectName = ‘BankSRS’, ModelingProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BankSRS.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\bin\Debug\BankSRS.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll’]’ }
transitiveReferenceClosure = { ‘[ModelingProjectName = ‘SharedComponentsSRS’, ModelingProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\SharedComponentsSRS.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\bin\Debug\SharedComponentsSRS.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\BusinessLogic\bin\debug\SharedComponentsSRS.BusinessLogic.dll’]’, ‘[ModelingProjectName = ‘SharedLibrary’, ModelingProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\SharedLibrary.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll’]’, ‘[ModelingProjectName = ‘BankSRS’, ModelingProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BankSRS.dynamicsproj’, BusinessLogicProjectPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\BusinessLogic.csproj’, ModelingAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\bin\Debug\BankSRS.Model.dll’, BusinessLogicAssemblyPath = ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll’]’ }
connectionStringModifier = ‘System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]' Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.AllAXCultures at 12:15:26.104 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.GetAxCultureIds at 12:15:26.106 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployInTempDomain at 12:15:26.136 reportLibrariesToDeploy = { '[ModelingProjectName = 'BankSRS', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BankSRS.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\bin\Debug\BankSRS.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll']' } transitiveReferenceClosure = { '[ModelingProjectName = 'SharedComponentsSRS', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\SharedComponentsSRS.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\bin\Debug\SharedComponentsSRS.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\BusinessLogic\bin\debug\SharedComponentsSRS.BusinessLogic.dll']', '[ModelingProjectName = 'SharedLibrary', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\SharedLibrary.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll']', '[ModelingProjectName = 'BankSRS', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BankSRS.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\bin\Debug\BankSRS.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll']' } cultures = { 'ar', 'cs', 'da', 'de', 'de-AT', 'de-CH', 'en-AU', 'en-CA', 'en-GB', 'en-IE', 'en-IN', 'en-MY', 'en-NZ', 'en-SG', 'en-US', 'en-ZA', 'es', 'es-MX', 'et', 'fi', 'fr', 'fr-BE', 'fr-CA', 'fr-CH', 'hu', 'is', 'it', 'it-CH', 'ja', 'lt', 'lv', 'nb-NO', 'nl', 'nl-BE', 'pl', 'pt-BR', 'ru', 'sv', 'th', 'tr', 'zh-Hans', '' } logger = 'Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger' connectionStringModifier = 'System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer+DomainBoundDeployer.Deploy at 12:15:26.765
connectionStringModifier = ‘System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]' Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DetermineRootFolder at 12:15:26.807 Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.Deploy at 12:15:27.519 reportLibrariesToDeploy = { '[ModelingProjectName = 'BankSRS', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BankSRS.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\bin\Debug\BankSRS.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll']' } transitiveReferenceClosure = { '[ModelingProjectName = 'SharedComponentsSRS', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\SharedComponentsSRS.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\bin\Debug\SharedComponentsSRS.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\BusinessLogic\bin\debug\SharedComponentsSRS.BusinessLogic.dll']', '[ModelingProjectName = 'SharedLibrary', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\SharedLibrary.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\bin\Debug\SharedLibrary.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll']', '[ModelingProjectName = 'BankSRS', ModelingProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BankSRS.dynamicsproj', BusinessLogicProjectPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\BusinessLogic.csproj', ModelingAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\bin\Debug\BankSRS.Model.dll', BusinessLogicAssemblyPath = 'C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll']' } cultures = { 'ar', 'cs', 'da', 'de', 'de-AT', 'de-CH', 'en-AU', 'en-CA', 'en-GB', 'en-IE', 'en-IN', 'en-MY', 'en-NZ', 'en-SG', 'en-US', 'en-ZA', 'es', 'es-MX', 'et', 'fi', 'fr', 'fr-BE', 'fr-CA', 'fr-CH', 'hu', 'is', 'it', 'it-CH', 'ja', 'lt', 'lv', 'nb-NO', 'nl', 'nl-BE', 'pl', 'pt-BR', 'ru', 'sv', 'th', 'tr', 'zh-Hans', '' } logger = 'Microsoft.Dynamics.Framework.Deployment.Reports.DeploymentLogger' connectionStringModifier = 'System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]’
Begining deployment on Monday, August 20, 2012 12:15:27 PM.
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateSrsInstance at 12:15:27.711
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployBusinessLogicAssemblies at 12:15:27.786
businessLogicAssemblies = { ‘SharedComponentsSRS.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘SharedLibrary.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘BankSRS.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ }
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 12:15:27.79
assemblies = { ‘SharedComponentsSRS.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘SharedLibrary.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘BankSRS.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ }
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 12:15:27.857
assembly = ‘SharedComponentsSRS.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 12:15:28.106
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 12:15:28.108
assembly = ‘BankSRS.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 12:15:28.111
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CopyAssemblies at 12:15:31.117
sourceAssemblyPaths = { ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedComponentsSRS\BusinessLogic\bin\debug\SharedComponentsSRS.BusinessLogic.dll’, ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\SharedLibrary\BusinessLogic\bin\debug\SharedLibrary.BusinessLogic.dll’, ‘C:\Users\Administrator\AppData\Local\Temp\tmp8AF9.tmp\BankSRS\BusinessLogic\bin\debug\BankSRS.BusinessLogic.dll’ }
binDir = ‘C:\Program Files\Microsoft SQL Server\MSRS10_50.AX2008SQLSERVER\Reporting Services\ReportServer\bin’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.GrantBusinessLogicAssembliesSessionPermission at 12:15:31.31
assemblyPaths = { ‘C:\Program Files\Microsoft SQL Server\MSRS10_50.AX2008SQLSERVER\Reporting Services\ReportServer\bin\SharedComponentsSRS.BusinessLogic.dll’, ‘C:\Program Files\Microsoft SQL Server\MSRS10_50.AX2008SQLSERVER\Reporting Services\ReportServer\bin\SharedLibrary.BusinessLogic.dll’, ‘C:\Program Files\Microsoft SQL Server\MSRS10_50.AX2008SQLSERVER\Reporting Services\ReportServer\bin\BankSRS.BusinessLogic.dll’ }
securityPolicyFilePath = ‘C:\Program Files\Microsoft SQL Server\MSRS10_50.AX2008SQLSERVER\Reporting Services\ReportServer\rssrvpolicy.config’
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateAllRequiredFoldersIfNecessary at 12:15:31.911
cultures = { ‘’, ‘ar’, ‘cs’, ‘da’, ‘de’, ‘de-AT’, ‘de-CH’, ‘en-AU’, ‘en-CA’, ‘en-GB’, ‘en-IE’, ‘en-IN’, ‘en-MY’, ‘en-NZ’, ‘en-SG’, ‘en-US’, ‘en-ZA’, ‘es’, ‘es-MX’, ‘et’, ‘fi’, ‘fr’, ‘fr-BE’, ‘fr-CA’, ‘fr-CH’, ‘hu’, ‘is’, ‘it’, ‘it-CH’, ‘ja’, ‘lt’, ‘lv’, ‘nb-NO’, ‘nl’, ‘nl-BE’, ‘pl’, ‘pt-BR’, ‘ru’, ‘sv’, ‘th’, ‘tr’, ‘zh-Hans’ }
srs = ‘[Url = ‘http://axcom/ReportServer/ReportService2005.asmx’, UseDefaultCredentials = ‘True’, Timeout = ‘100000’]’
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateFolderIfNecessary at 12:15:31.916
path = ‘/Dynamics’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.LoadModels at 12:15:32.053
allModelAssemblies = { ‘SharedComponentsSRS.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘SharedLibrary.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘BankSRS.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ }
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 12:15:32.054
assemblies = { ‘SharedComponentsSRS.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘SharedLibrary.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’, ‘BankSRS.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ }
assembly = ‘SharedComponentsSRS.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
assembly = ‘SharedLibrary.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
assembly = ‘BankSRS.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.TransitiveClosureNotInGac at 12:15:32.055
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployModelElements at 12:15:34.269
reportTuples = { ‘[First = ‘BankaccountReconciliation’, Second = ‘BankSRS.BusinessLogic, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’]’ }
connectionStringModifier = ‘System.Func2[System.Collections.Generic.IDictionary2[System.String,System.String],System.Collections.Generic.IDictionary2[System.String,System.String]]' getSrs = 'System.Func1[Microsoft.Dynamics.Framework.Deployment.Reports.ReportingService2005.IReportingService2005]’
Deploying 0 data source(s) and 1 design(s) in 42 culture(s) (42 item(s) total)…
Thread 3: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.DeployDataSources at 12:15:34.568
dataSourcesToDeploy = { }
updateProgress = ‘System.Action’
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateFolderIfNecessary at 12:15:34.849
path = ‘/Dynamics/ar’
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateFolderIfNecessary at 12:15:34.86
path = ‘/Dynamics/cs’
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateFolderIfNecessary at 12:15:34.87
path = ‘/Dynamics/da’
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateFolderIfNecessary at 12:15:34.881
path = ‘/Dynamics/de’
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateFolderIfNecessary at 12:15:34.891
path = ‘/Dynamics/de-AT’
Thread 8: Entering Microsoft.Dynamics.Framework.Deployment.Reports.ReportLibraryDeployer.CreateFolderIfNecessary at 12:15:34.902
path = ‘/Dynamics/de-CH’
path = ‘/Dynamics’
Hi Lalit,
The Main post is the log file which i have pasted
mother fucker
