SSRS deployment issue.
When we deploy the standard AX 2009 SSRS report, following error shown in the log file.
Could not load file or assembly ‘Microsoft.Dynamics.Kernel.Client, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.AppDomain.Load(String assemblyString)
at ClrBridgeImpl.LoadAssembly(ClrBridgeImpl* , Char* assemblyName)
at ClrBridgeImpl.GetTypes(ClrBridgeImpl* , Char* assemblyName, Boolean* isException)
Could not load file or assembly ‘Microsoft.Dynamics.ReportingServices, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.RfidProxy, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
Could not load file or assembly ‘Microsoft.Dynamics.SysImport, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified. at System.Reflection.Assembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, Assembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection)
at System.Reflection.Assembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection).
I checked the windows assembly for all above dlls, these are registered with right version. AOS and Reporting services are on same server.
When i modified the standard report in VS, on build it is throwing following error,
The data method ‘xxxxxxxx’ is present in the model but not in the business logic assembly.
Thanks in advance.
have you got the solution for your above problem ??? i am facing the same error
anyone got the solution for this pblm… am also facing the same pblm
Did you find the solution ?
me also facing same problem with several days…
can anyone solve this problem…please…
