Deletion of unused dimension
Hi!
I’ve added a dim number and connected an employee to it, after a day the finans resp. told me that it should be a different id for his dimension.
I added a new dimension, and connected the employee to it, unconnected him from the original dim and tryed to delete the original unused dimension but get the message that there are transactions for this dimension and therefor can not be deleted. I can not find any transactions. looking at delete action methods LedgerTrans and LedgerBudget(not used) and the tables does not have any transactions with the original dim.
Where can I possibly find this dimension transaction?
Next time rename the original dimension.
The error message should tell you what transactions, if not you will need to debug it and locate which ones it is referencing.
