regarding CustAging Report, basically i want to dispaly customer Address on same report, for this i just work Around which is:
1.Add new string field in CustAgingReportTmp name is Address, then create new method in custAgingReportDp code is
public str GetCustomerAddress(Accountnum _accountNum)
str address;
select * from custTable
where custTable.Accountnum==_accountNum;
address=custTable.address();
return address;
then in insertintoCustAgingTmp method of CustAgingReprotDP class, i just called the above method ,i.e
customerAddress=this.getCustoemrAdress(tmpaccountSum.accountNum);
and then place that cusomerAddresss string to insertRecordSet ,
when i debugging the code, so that time the value is showing , but on report no data populated, plz guide me where i making mistake…Thanks & Regards
This method uses a set based operation to insert the records into custAgingReportTmp. Not sure how did you added the code here. The records are being inserted from \Data Dictionary\Tables\CustTmpAccountSum.
Try adding a field to CustTmpAccountSum and update it in \Classes\CustBalanceList\insertIntoTmpAccountSum.
Moving to Developer forum. Please post in the relevant forum.
Thanks Metin Emre, i already added address field at Account num level in ssrs Desgin…can you share me the step of how you added new fields in that report…plz
