report display method
Hi
i want to customize a standard report called custagingreport. I want to bring some fields from projtable to this report. i wrote a display method by taking custaccount as a common field in both the table. I wrote a select statement but this is not working. can anybody suggest me what should i do
It really matters where and what you have written…
select projTable
where projTable.CustAccount == custTable.AccountNum;
return projTable.projid;
i wrote this in custtable body of the custagingreport.
The body will get printed only when the details - is selected while opening the report.
***The customer may have more than one projects…
i am opening the report from menuitem. the customer has more than one project. In that case what is the solution?
What is your requirement - how you/customer wants the report to be displayed?
i want to display the projid field in the custagingreport, the actuall report shows the customer balance as on date, i want to display projid if supose any transactions related to projid means, It has to show projid value for those transactions.
Tell the requirement correctly
In custagingreport i want to display the projid field values. this is the requirement.
