Finally I’ve written something based on your code.
I had to consider following cases:
insert new primary address;
insert new additional address;
update existning primary address;
update existing additional address;
change of existing primary address to additional address;
change of additional primary address to existing address;
My method:
// bar0016_AccountsReceivable 20/04/2011 by WP@arnam (Piotr PB. Bartkowiak)
static container CustomerAddresIU(AccountNum _CustAccount,
RefRecID _AddrRecId, //if != 0 then update existing address
boolean _PrimaryAddress, //if true disable current primary address and update data on CustTable
AddressType _AddressType,
AddressStreet _Street,
AddressCity _City,
AddressZipCodeID _ZipCode,
AddressCountryRegionId _CountryRegionID,
WPExternalID _ExternalID
CustTable _CustTable;
Address _Address, _AddressDisable;
AddressMap _AddressMap;
boolean _NewAddress = true;
container _AddressRecIds;
RecId _AddressRecId;
DirPartyTable _DirPartyTable;
_CustTable = CustTable::find(_CustAccount, true);
if (!_CustTable)
return connull();
_Address = Address::findRecId(_AddrRecId, true);
if (_Address)
_NewAddress = false;
//get Customer’s DirPartyTable
if (!_CustTable.PartyId)
_DirPartyTable = DirParty::createPartyFromCommon(_CustTable);
_CustTable.PartyId = _DirPartyTable.PartyId;
_CustTable.update();
else
_DirPartyTable = DirPartyTable::find(_CustTable.PartyId);
if (_PrimaryAddress) //if inserting or updating address which is primary
//disable current primary address
_AddressDisable = WPARDataCreator::getPrimaryAddress(_DirPartyTable.PartyId);
if (_AddressDisable)
if (
(_NewAddress) || //when adding new address
((!_NewAddress) && (_AddressDisable.RecId != _Address.RecId)) //or address which is being updated is not primary
DirPartyAddress::changePrimaryToAltAddress(_AddressDisable);
//set new primary address data on CustTable
_CustTable.Street = _Street;
_CustTable.City = _City;
_CustTable.ZipCode = _ZipCode;
_CustTable.CountryRegionId = _CountryRegionID;
_CustTable.Address = Address::formatAddress(_CustTable.Street,
_CustTable.ZipCode,
_CustTable.City,
_CustTable.CountryRegionId,
if (_NewAddress) //create new address based on CustTable data
dirparty::updatePartyFromCommonInsert(_CustTable.PartyId, _CustTable, false);
else // or update existing address
DirPartyAddress::changeAltAddressToPrimary(_Address);
dirparty::updatePartyFromCommon(_CustTable.PartyId, _CustTable);
if (_NewAddress) //find newly added address
_Address = address::find(_DirPartyTable.TableId, _DirPartyTable.RecId, AddressType::None, true);
else
_Address.reread(); //or reread address data updated from CustTable
if (_Address.RecId != 0) //update AddressType
_Address.type = _AddressType;
_Address.update();
else //if updating or inserting address which is not primary
if (_NewAddress) //init address data
_Address.clear();
_Address.initValue();
_Address.AddrRecId = _DirPartyTable.RecId;
_Address.AddrTableId = tableNum(DirPartyTable);
_Address.Street = _Street;
_Address.City = _City;
_Address.ZipCode = _ZipCode;
_Address.CountryRegionId = _CountryRegionID;
_Address.Address = Address::formatAddress(_Address.Street,
_Address.ZipCode,
_Address.City,
_Address.CountryRegionId,
if (_NewAddress)
_Address.insert();
else
_Address.update();
return [_Address.RecId];
What do you think about it?
