I a client in Nav 5 the problem is that whenever I run the currency Adjustment batch job. the figures I am getting are not correct. How can I reverse the batch job. 2. Is there a way of resseting the Currency adjustment register as the incorrect batch jobs have been registered.
Hi Danny and welcome to forum!
If you “get incorrect figures”, reasons are 2:
- You have incorrect forex rates OR no forex rates for dates in question, so Navision uses nearest oldest date forex rate.
- You have unapplied (Open) transactions - Invoice(s) are paid, but not applied to Payments, and Navision continues doing unnecessary adjustments.
You don’t need (and actually can’t) delete “errorenous” adjustment entries. Solve two issues I wrote hereabove, then run Adj. batch job again, and everything will be corrected.
Unneccesary Adjustments for unapplied entries will actually be corrected, when you “apply” corresponding entries.
