Can anyone please tell how we can Create or add more than one view into a view for getting different fields from each of the views in one parent view ax 2012
Thanks in advance,
Gopinath M
Thanks in advance,
Gopinath M
Not clear about your requirement. What issue do you have?
Have a look at \Data Dictionary\Views\PurchLineAllVersions
I wanted to add 3 different views into a main view and I should collect all the fields and show it as one view in that main view, Is it possible to do so?
It should be. have you seen that example?
You can use views as data sources for another view, but you have to do it indirectly. Create a query using those views and then use this query in the definition of your master view.
